Author Topic: analog filter stability ideas  (Read 2536 times)
Offline phil2014Topic starter
« on: April 05, 2016, 02:28:54 am »
Hi all,
I have the following LTSpice low pass filter circuit simulation and resultant ac analysis (full ltspice project is attached).  The problem is that the first filter stage oscillates in my test PCB - even without load (delete R1).  The second stage is stable.
I am looking for ideas on how to improve circuit stability and am hoping someone with more experience can guide me in the right direction.
Regards
Offline R_G_B_
Re: analog filter stability ideas
« Reply #1 on: April 05, 2016, 07:32:02 pm »
This is useful to watch on amplifier stability:
R_G_B
« Last Edit: April 05, 2016, 07:36:48 pm by R_G_B_ »
R_G_B
The following users thanked this post: diyaudio
« Reply #2 on: April 05, 2016, 07:46:00 pm »
Thanks.  For the link.  After reading up a bit more I decided to increase the phase margin by reducing band pass ripple.  The circuit no longer resonates  :)
Offline diyaudio
« Reply #3 on: April 08, 2016, 10:28:38 am »
R_G_B
