Author Topic: ADC circuit  (Read 1887 times)
Offline comeauTopic starter
ADC circuit
« on: May 28, 2017, 02:29:32 am »
Hello all,
I've been rattling around with idea I have and I think it might be good. It also might be terrible. I have no idea.
Basically, it is an ADC that should ideally work as fast as a flash ADC, but use only 3 comparators per stage vice the 2^n of a flash ADC. The savings are clear (if it works). At just 3 bits of resolution, you are saving 2 comparators. At full 8-bit resolution, you are saving 232 comparators.
Obviously, it is too good to be true.
The system takes an input signal, compares it to a reference voltage and outputs a binary signal. The clever bit is that it then switches a mosfet to reduce the input signal by the reference voltage and then uses that as an input to the next stage. The input signal continues to get chopped in this way until it reaches the last stage.
I built this circuit in LTSpice and it seems to work at least up to 1kHz. I think I can get it to work up to higher frequencies and in real life. Before I waste more time however, I would like a second opinion. The LTSpice circuit is attached as well as a picture.
I request the following free services:
1) Has this already been done? If true=>project end
2) Is there a basic reason this circuit won't work in real life? If true=>project end
3) Is there an obviously better way to do this?
-Comeau
« Last Edit: May 28, 2017, 02:35:42 am by comeau »
The following users thanked this post: hamster_nz
Offline Helix70
  • VK4JNA
Re: ADC circuit
« Reply #1 on: May 28, 2017, 06:23:40 am »
What problem are you solving?
Offline ebclr
Re: ADC circuit
« Reply #2 on: May 28, 2017, 06:41:38 am »
You can do with only 1 comparator
http://www.ti.com/lit/an/slyt423a/slyt423a.pdf
Re: ADC circuit
« Reply #3 on: May 28, 2017, 10:55:58 am »
To answer both your questions at once. A delta-sigma ADC has a set sampling rate. This reduces the ability to convert at a much higher frequency. The alternative for lightning fast response is to have 2^n comparators in a flash ADC. This is expensive and impractical and it looked like an improvement could be made.
There is more than 1 comparator in a delta-sigma ADC.
I'm imagining an ADC that is all the fast (solely limited by circuit design and processor speed) and is also incredibly accurate. This ADC, if it works, would have the potential for unheard of accuracy at relatively cheap prices. (optimistic)
Anyways. From the general lack of compelling counters, it seems like this might be worth actually building up after all.
