Charging a series ni-mh pack or lead-acid pack doesn't require such delicate balancing.
It definitely does, for the exact same reasons. This is also why there are no nicd/nimh charges that charge user-supplied single cells in series - they
always charge each cell separately. Cells charged in series are always inside a factory-built pack, meant to be charged using the factory-supplied charger only.
"Normal users" also never charge separate lead acid cells in series - they practically always charge a factory-built 3s or 6s pack, which cannot be taken apart.
Li-ion packs do not
always use "delicate" balancing, but sometimes the exact same measures are enough - for example, BOSCH power tools use 4s and 6s li-ion packs identical to the style used in NiCd/NiMh packs - all cells are in series, with no center taps nor any management nor protection circuitry present. The cells stay in balance well enough.
The most important reason IMO why 18650 is not and should not be used as a changeable cell by general public is that they can provide very high short circuit currents and can short accidentally easily due to the construction - the negative terminal is the case, which is also present around the positive tab; and the positive tab is actually
further inside. A simple scratch can damage the plastic sleeve so that the cell is accidentally shorted.
