Author Topic: Help identify part  (Read 1085 times)
Offline robson2017Topic starter
Help identify part
« on: August 15, 2018, 05:56:38 pm »
Hello everybody,
could you help me identify parts.
I think they are Texas Instrument but i'm not shure on 100% in 10-SSOP(MSOP) case.
Top of it has the symbol 17TI ATK.
Thanks
R.
« Last Edit: August 15, 2018, 07:45:00 pm by robson2017 »
Offline mdszy
  • somehow has an ee degree
    • szy.io
Re: Help identify part
« Reply #1 on: August 15, 2018, 08:18:33 pm »
Hello everybody,
Thanks
R.
Seems to be a TPS60312DGS according to the datasheet for that series of chips. They're charge pump ICs.
« Last Edit: August 15, 2018, 08:31:03 pm by mdszy »
somehow allowed to be a Pixie Wrangler in Training
eBay Store | My site | Hackaday.io Projects | my mastodon.technology profile
« Reply #2 on: August 15, 2018, 08:42:53 pm »
Thanks for help.
When you put "ATK" on this link :
http://www.ti.com/packaging/docs/partlookup.tsp#divline
you are right it should be TPS60312DGS
But i was thinking that i need put full symbol "17TI ATK" because i can't find anything.
In future, should i only use the last 3 symbols?
With Regards
R.
Offline mdszy
    • szy.io
« Reply #3 on: August 15, 2018, 08:44:46 pm »
Thanks for help.
With Regards
R.
If you're searching TI's listing then yes, I believe they only use the last three. The "17TI" is more of a manufacturer mark than a part number, and maybe the 17 part is a datecode. I just googled "17TI ATK IC" and one of the top results was the PDF datasheet. Googling "17TI ATK" didn't find anything, though, so including "IC" or "chip" or a possible manufacturer can help with searching.
« Last Edit: August 15, 2018, 08:47:02 pm by mdszy »
« Reply #4 on: August 15, 2018, 09:11:21 pm »
Ok, many thanks for info
R.
« Reply #5 on: July 05, 2019, 04:18:48 am »
Hello,
I'm trying to identify  F050 (E050) part SOT-23 (5).
R.
« Last Edit: July 05, 2019, 04:51:40 am by robson2017 »
