Author Topic: Adding 100Mbps ETH to an R&S ZVx Network Analyzer  (Read 868 times)
Offline sixtimessevenTopic starter
    • Flickr
« on: December 21, 2019, 12:21:47 pm »
I would really like to add 10 or better 100mbps ETH to my Rohde Schwarz ZVR VNA.
There is a R&S option for it, however it's only base10, not available used and likely obsolete and or too expensive so  :-/O
The instrument runs Win NT 4 which I have zero expirience with so far. On the bright side, the backplane / mainboard / plugins do have 3x ISA extension slots so should be straight forward(ish).
At the moment I would be interested in pictures of ZVx's with installed ETH options as a reference  :)
Offline george.r
  • not to be confused with other georges
Re: Adding 100Mbps ETH to an R&S ZVx Network Analyzer
« Reply #1 on: December 23, 2019, 06:17:26 am »
What a delightfully weird piece of gear. Seems like it runs on an Eurocard SBC. WinNT4 looks like a crossbreed between W98 and W2k (because that's what it essentially is - a W9x-ish interface tacked atop an NT kernel, Windows 2000 being NT5). You won't find too much difficulty fiddling with it. NT4 lacks a device manager, but that's the only major weirdness (or so have I found). Something like a 3Com 3C515TX ought to work. The Ethernet card R&S originally installed is an SMC 8416 EtherEZ. But anything with the proper NT4 drivers should work.
Copper scribbler, garbage hoarder
The following users thanked this post: sixtimesseven
