I'm plugging a USB device into a USB battery pack. After a minute or so, the battery stops supplying power.
I've tried two different battery packs, both bought from Amazon a while back, and neither is still being sold.
The device is a USB to 12V "cigarette lighter" converter (
https://www.amazon.com/dp/B093KXL19S). After a short while, it loses power, even if I haven't put a load on the 12V side.
If I plug the converter into a USB AC adapter, it stays powered on indefinitely.
Is this a problem of the converter not doing any power negotiation? It seems inconceivable that the battery packs would require it; I would expect them to happily provide 5V and at least 1.5A forever.
Any thoughts?
Thank you.
