Author Topic: where to connect resistor on LT3015 parallel operation? (neg ldo)  (Read 519 times)
Offline coppercone2Topic starter
The datasheet for the LT3015 has a circuit for parallel operating chips involving a op-amp.
It uses 0.01 ohm resistors for each op - amp, and a sense on the line between the resistor and the op amp.
Should the trace be connected at the 0.01 ohm resistor, or at the input to the chip?
i put red and green dots
Online moffy
Re: where to connect resistor on LT3015 parallel operation? (neg ldo)
« Reply #1 on: November 19, 2023, 09:47:56 pm »
At the 0.01R resistors, that is what you are measuring the voltage drop over, extra trace will just add extra resistance.
The following users thanked this post: tooki, PCB.Wiz
Offline PCB.Wiz
« Reply #2 on: November 19, 2023, 09:49:46 pm »
As drawn looks correct.
The top regulator defines VOUT, and the Opamp compares the current draw, and nudges the setting of the lower regulator, to give equal average currents.
Such a circuit may need care at very low load currents.
« Reply #3 on: November 19, 2023, 10:07:08 pm »
yeah that is what I did, I put the trace right at the end of the resistor (I used a wire shunt from digikey).
The regulators are hard to space evenly because I wanted a single extruded heat sink so the traces are unequal.
