The electrical isolation is guaranteed by the precision in the assembly process only. The TO-220 package height above the PCB is fixed and so is the heat sink height. The other heat sink on the case is also fixed at a constant location by marking it.
My issue is with the case style. The case I am using is a aluminium extrusion with open ends on two sides. The PCB slides into the case from the sides. So there is no easy way for me to access the package once the PCB is inside.
As you said you can do precision assembly process, although not used at extrusion style case, below are examples used a lot at common switching psus, this is from Meanwell.
I'm guessing this technique can be implemented in your case, all you need is just to precisely drill a hole at the case for the screw, and provide a metal insert sandwiched between the case and the TO-220 body as below.
The gray box is a TO-220 encased inside a box style thermal pad (cap) as above Wraper's example post, as this is a HV transistor, its secured using a strong "L" shaped steel with a hole (threaded) for the screw, when fastened will make the L steel pressing the TO-220 body, and its secured/fastened from "outside" of the case.
Same as above, this is the schottky diode using the same securing style. You see clearly a big piece of metal insert behind.
