Author Topic: Adding Primary turns to a Microwave Oven Transformer, 22Volt secondary  (Read 2409 times)
Offline QmavamTopic starter
Hi all,
 I removed the HV winding from a MOT, and thought I could just wind a new secondary. I find the Primary magnetizing current is very high. Another group said I needed to add primary turns.
I'm trying to figure out where to stop adding turns. I have a graph showing the original, with 37 turns added, 48 turns added and 60 turns added.
 Can anyone look at the graph and say, that's good enough, put your secondary on.
 The 22V secondary will have an 8 amp load.
                                    Thanks, Mikek
Offline duak
The desired magnetizing current is up to you.  You can reduce it but then the maximum power the transformer can deliver is also reduced.  I think the function is roughly reciprocal ie. Imag = f(1/N) - try plotting magnetizing current  as a function of the number of turns for your expected primary voltage.
I remember reading an article somewhere that described the rationale behind MOT design.  I thought it was this one: https://www.qsl.net/kh6grt/page4/xfmr/xfmr.htm   but it's not.  It's worth a read if you haven't seen it.
I understand that for the most part, MOTs run at full secondary current except during the time that the magnetron's heater is warming up and the anode current is reduced.  Because the secondary load current cancels out the magnetic flux developed by the primary current, increasing the secondary current moves the transformer away from saturation.  The designer can then use a smaller core that can saturate at a lower primary voltage than for equipment that does not operate at full current.
Bottom line, if the transformer will not operate at high load current almost all the time, the losses due to the magnetizing current can be significant.
« Last Edit: June 29, 2020, 10:10:17 pm by duak »
My use is to power a Battery operated leaf blower. (The battery and charger are gone)
Yes, I'll use a bridge rectifier.
It will draw 8 amps when running and 0 amps when the leaf blower is switched of.
I can't make sure power to the primary will always be switched off, so I should lower the
magnetizing current. I should not have much problem getting a 180 watts from a transformer
that did output 900 watts.
 Any other advice?
                                   Mikek
Offline floobydust
I see why you are lowering the flux density in the transformer, but it has consequences. You will need more turns on both windings, so copper losses go up.
If a typical MOT is 0.8V/turn your (sec) 28 turns may go up to 33. Measure the window size and see if you can still fit the ~20% more (secondary) turns plus the extra primary turns. I'd guess you have a 150T primary to start with.
If you are adding primary turns in the secondary window, there is a safety issue in keeping decent high-voltage insulation and spacings between the primary to secondary.
Magnetization current is a non-linear waveform and you need to use a decent true RMS ammeter for accurate data or better yet a true power meter to compare those losses in the transformer.
Offline duak
I happened to have a 120 V, 50 VA transformer on the bench and measure about 120 mA AC with the secondary unloaded.  Extrapolating to 200 W, a reasonable magnetizing current might be 480 mA.  60 extra primary turns should easily meet this and also allow for the output current.  As Floobydust points out, is there room?
How hot does the transformer get?  The last microwave I looked at air cooled the transformer as well as the magnetron.
BTW, I found out from that article that some MOTs have a magnetic shunt.  I didn't know that.  I knew that some battery chargers have them to act as a voltage regulator and current limiter.  Does your MOT have a shunt?
 Adding turns on the Primary will reduce the turns needed on the secondary.
 Yes that 0.8y/turn is a accurate. I have lots of room for all the extra turns and more. They are a little hard to get an accurate count, but I measured the voltage ratio between the 60 added turns and the original winding with 100V applied. 60 turns had 30v across it, the original 70v, so... I think the original winding has 140 turns.
I have lots of room for seperation and I have hybrid insulating sheets made for electric motor rewinding.
Hmm... I'm using Dave's BM235 meter, I don't know how to relate the unknown primary current waveform to the crest factor numbers listed in the manual,  Maximum Crest Factor <2:1 at full scale & <4:1 at half scale. I'm using a 1 ohm resistor in series to measure current.
https://www.eevblog.com/files/BM235-Manual-EEVblog.pdf
« Last Edit: June 30, 2020, 02:48:53 pm by Qmavam »
IF extrapolating is an accurate method, I'm looking good, with the added 60 turns I have 470 ma of magnetizing current!
Loads of room.
 With 60 added turns it won't get hot.
Yes it has two, one in each window, positioned between the primary and secondary. Here's an example of what the core looks like.
(Attachment Link)
