Author Topic: Adding Test points to a PCB  (Read 2774 times)
Offline mendezTopic starter
« on: October 04, 2019, 12:43:41 am »
I'm trying to add test points to my PCB so that I can monitor/sense analog signal with an oscilloscope or a test lab box WITHOUT causing interfering/adding noise to the data. The question is: can someone point me to the right direction on how to do this?
I plan on using BNC connectors and Test Points.
Please see attachment for an example of what I'm trying to accomplish.
Offline DaJMasta
    • medpants.com
Re: Adding Test points to a PCB
« Reply #1 on: October 04, 2019, 05:07:12 am »
It depends on the sensitivity of the sensor, the thing measuring it, and its output characteristics, so it can be a complicated thing to answer.
That said, if you're measuring the sensor directly with the micro, it's probably not all that sensitive to a lot of noise (there's already a fair amount built in), so make sure your measuring instrument has a fairly high impedance and use shielded cables to connect the points and the device.  Basically what you'd have to worry about is noise picked up on the measurement line, provided your source impedance is low enough that the added measurement of it doesn't draw the voltage down (and provided this is a voltage measurement), but unless your test points are in a shielded box, you're still gonna get at least a bit picked up on the board itself.
If it were me?  Add test a test point for the signal and ground (a solder-in loop is great for oscilloscope hookups, but you can use wide through hole pads on the edge of a board or a bit of wire with a loop soldered to a blank pad), keep them fairly close together, and just clip the probe in normally.  A scope isn't going to be super high resolution on the vertical scale (they're not designed for it), and your micro is probably reading its ADC with similar or slightly higher noise levels than the scope, so it's likely that your application is not sensitive enough for the probing to matter much.  The easy sanity test would be to measure your device on the micro, then connect the scope and measure on the micro again.  If the readings are consistent, your scope probe probably isn't injecting enough noise to make a problem.
Offline tautech
« Reply #2 on: October 04, 2019, 05:24:28 am »
Place a 0805 footprint onto the traces you need to get measurements from. Assign both pads to the same net as the trace. Take your pick from these SMD test points and just solder them on.
https://www.digikey.co.nz/en/product-highlight/k/keystone/surface-mount-test-points
I like the first one, it's small and tidy and easily reusable.
Normal scope probes grabbers have no trouble securely connecting to them.
