Author Topic: Adhesive for IDC connectors?  (Read 1226 times)
Offline daqqTopic starter
  • Country: sk
    • My site
« on: August 21, 2019, 06:18:26 am »
Hi guys,
I need to vibration proof (or maybe shock proof) a device that uses several IDC connectors with flat cables ( similar to this: https://uk.farnell.com/multicomp/mc-254-10-00-00-idc/connector-rcpt-10pos-2row-2-54mm/dp/2843495 ), mated into the PCB through a classic counterpart (similar to: https://uk.farnell.com/hirose-hrs/hif3fc-20pa-2-54ds-71/connector-header-20pos-2row-2/dp/2724804 ).
My question is, what would you recommend to keep them in? Something like the adhesive used on tall electrolytic capacitors ( https://www.robotroom.com/Parts/Samsung-monitor-capacitors/Healthy-capacitor-with-flat-clean-top-and-flush-to-board.jpg )? Ideally something stocked at farnell that can be applied with a syringe (parts of the device are really really hard to get into with anything big.
Thanks,
Online voltsandjolts
Re: Adhesive for IDC connectors?
« Reply #1 on: August 21, 2019, 07:15:50 am »
Expensive but it works nicely:
Dow Corning 3145
https://uk.farnell.com/537007
« Reply #2 on: August 21, 2019, 07:33:06 am »
Look for fabric tapes.
These are commonly used to keep ribbon cables secure in test equipment.
Example:
https://nz.rs-online.com/web/p/cloth-tapes/9054214/
« Last Edit: August 21, 2019, 07:56:35 am by tautech »
Online David Hess
  • DavidH
« Reply #3 on: August 21, 2019, 02:11:16 pm »
Use a latched IDC header.
Online coromonadalix
« Reply #4 on: August 21, 2019, 02:20:02 pm »
Th latched idc is okay,  but sometimes you need to lock the latchs too,    small dab of sillicone on them ..
