As I have told you I have a bunch of PIC16F72 and this breakout hopefully broke all pins out in appropriate ways. I will spin a few of those boards (with my VoltCard Original) and if it worked I will open source it for you.
PICKit connector on the left, using straight pins up. Crystal on the right, I will probably use 16, 20 or 24MHz.
