Author Topic: Adjustable Slewrate  (Read 495 times)
Offline lukaev3Topic starter
Adjustable Slewrate
« on: November 14, 2024, 12:24:05 pm »
Hello,
I have the following issue I cannot resolve. My output signal is from a DAC; it swings between -5V and 5V, outputting a square wave with variable duty cycle, Vmin, and Vmax.
Now to my question:
How can I have an adjustable slew rate on the rising and falling edges (it can be the same for both falling and rising)?
Example: When transitioning from 1V to 3V and back, the slew rate/ramp should be adjustable. The slew rate is preferably set by a voltage or current.
The slew rate should be a maximum of 1V/μs and a minimum of 1V/ms.
I have thought about using integrators, but they don't stop at my desired value.
Additionally, I also thought about transconductance amps, but they would have a droop at the end of the slope, right?
Another way would be a diode bridge, but I need to vary the current sink/source with one control signal, which is not that easy as it seems to me.
Thanks in advance!
Offline MasterT
Offline David Hess
  • DavidH
Re: Adjustable Slewrate
« Reply #2 on: November 14, 2024, 02:40:57 pm »
Do you only have one analog control signal available?
« Reply #3 on: November 14, 2024, 02:57:54 pm »
I only have one DAC for my analog set point for now, but it would not be an issue to have a second...
As for the slewrate setting i was thinking of also using a 8bit dac so its not an issue :)
Offline PCB.Wiz
« Reply #4 on: November 15, 2024, 01:30:49 am »
I think an OTA could work quite well, you just need to power it with enough voltage it stays in the linear range. (eg +/-6V or more)
The OTA then works like a symmetric current limiter, so 1mA of bias and 1nF is 1V/us and 1uA of bias puts you in 1V/ms ballpark.
If you get a dual OTA, maybe you can use one channel to measure the current, and leverage the tracking ?
