Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Projects, Designs, and Technical Stuff
Adjustable Step up regulator
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Adjustable Step up regulator (Read 1127 times)
Aodhan145
Frequent Contributor
Country:
on:
May 09, 2015, 09:24:06 am »
Hi, I found this 150W Step up converter on Aliexpress, Would anybody be able to look it over to see if it is going to explode?
http://www.aliexpress.com/item/150W-DC-DC-Boost-Converter-10-32V-to-12-35V-6A-Step-Up-Voltage-Charger-Power/32260792513.html
Thanks in advance.
Logged
kjs
Regular Contributor
Country:
Re: Adjustable Step up regulator
Reply #1 on:
May 09, 2015, 09:47:17 am »
with just the 3 pictures it's impossible to judge anything. However, at an efficiency of 90% or less (the 94% are for sure optimistic) and 150W Pout the heatsinks looks a bit small. If you need half the power (75W) it most likely will do the job.
Logged
Aodhan145
Country:
Reply #2 on:
May 09, 2015, 11:03:56 am »
Thanks, I will look for a beefier module then.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
