Author Topic: How is this DAC output design called  (Read 2422 times)
Offline Zom-BTopic starter
« on: January 08, 2017, 01:21:05 pm »
  • How is this DAC output configuration called?
  • how can I search for DACs with this specific output configuration this on E14/RS/M/etc shops?
The part I found this output configuration in (apparently this part is being deprecated):
https://www.maximintegrated.com/en/products/analog/data-converters/digital-to-analog-converters/MAX5152.html
(background: I want to make a PSU similar to Dave's µSupply, but save on some external op-amps.)
« Last Edit: January 08, 2017, 03:14:49 pm by Zom-B »
Offline timb
    • timb.us
Re: How is this DAC output design called
« Reply #1 on: January 08, 2017, 03:16:27 pm »
That image doesn't really give enough information for us to tell you specifically what type of DAC it is, however it appears to be a dual output, buffered voltage DAC. At 16-bits it's most likely using an R2R ladder for each DAC.
Take a look at Linear Tech, Analog Devices and Texas Instruments. They all make 16-bit DACs and have parametric search pages that will let you filter by Current and Buffered/Unbuffered Voltage DACs.
That said, 16-bit is way overkill for a basic bench power supply, unless you need uA/uV level control of the output. (In which case you'd be better off with a current output DAC and a separate precision Op-amp!) 12-bits should do fine for you, 14-bits at the max.
« Reply #2 on: January 10, 2017, 06:53:11 pm »
What I'm referring to is the internal Op-amp before the output pins.
When I search for regular current and buffered voltage outputs, I get parts with an output stage that does not include an op-amp, or one that has a fixed / variable amplification, but without exposed feedback pins.
I checked four mfrs for 12-bit 2ch buffered voltage DACs, and finally found exactly one: MAX5156... which is also phased out. :(
BTW, something like MAX5154 with resistors between the output and FB lines is unacceptable, because I'd need external op-amps to shift the signal, defeating the purpose of internal op-amps.
« Last Edit: January 10, 2017, 07:04:40 pm by Zom-B »
Offline ajb
« Reply #3 on: January 10, 2017, 08:25:23 pm »
That's a neat feature, but there's nothing you could do with that part that you can't do with a couple of external op-amps.  In fact there's a lot more you can do with fully independent op amps, and you have lots of choices in MSOP8 and such packages that won't take up too much board space.
Offline timb
    • timb.us
« Reply #4 on: January 11, 2017, 02:39:48 am »
All buffered output DACs essentially include an internal op-amp after the DAC; that's why they're called buffered! Most don't break out the inverting pin and instead have it connected internally at the output.
Non-buffered voltage DACs essentially give you the weak output direct from the resistor ladder. A current DAC is similar, but it generally also provides access to additional parts of the R2R ladder (the Rf/Rg pins) which are used with an external op-amp hooked up as a current to voltage amplifier (most of the time current output DACs are really used to generate a voltage, it's just done outside the part for a variety of reasons, including precision).
Edit: If you want the best performance, get a current DAC and hook a high quality, low drift op-amp as stated above. That will essentially give you what you want.
« Last Edit: January 11, 2017, 02:44:53 am by timb »
Offline bson
« Reply #5 on: January 11, 2017, 09:38:04 pm »
They're called sense pins.  Sometimes they have resistors, at other times not.  See e.g. http://www.ti.com/product/dac7632
