Author Topic: Looking for vibration motor with industrial grade  (Read 523 times)
Offline muthukural001Topic starter
  • Country: in
« on: April 15, 2020, 09:54:50 am »
Hello,
I am searching for a mini vibration motor with industrial grade. All the motors that I am seeing is within -20C to 70C range. If anyone have come across the industrial grade mini vibration motor, please share.
Thanks
« Last Edit: April 15, 2020, 10:56:29 am by muthukural001 »
Re: Looking for vibration motor with industrial grade
« Reply #1 on: April 15, 2020, 10:07:54 am »
'Industrial Grade' is not remotely near defining what you actually want or need it to do and what sort of environment you 'need' it to work in?
Vibrating mechanisms/motors of all sorts are used for mixing or separating tasks in industry for example but will generally be designed as needed to do the job required rather than an off the shelf mechanism.
  • Country: in
« Reply #2 on: April 15, 2020, 11:09:40 am »
It is just to validate it on the PCB board.But, we are expecting that it's operating temperature range should be-40C to 85C
