Hi, I am looking for advice on the sourcing of rotary switches, specifically 12 position dual decks, and an 18 position quad deck. I need these for a future project I want to work on.
The main problem for me is my budget constraint. I don't want to spend $100 a piece for a single rotary switch on digikey. I was looking at ebay, but they don't have them.
I could use a uC and some relays, but I feel like nothing beats a good old fashioned rotary switch. Thanks.
All of those requirements paint you into a corner.
Amazingly, I do find a 18 pos 4 bank switch listed on Digikey, at $226 1 unit in stock, marketplace.
So you can see they are rare and very expensive.
If you want the rotary switch feel, you may be best to approach from the other direction, start looking for ANY rotary switch close to your position count.
A quick scan finds 18 is rare, but Alps have a 20 position SRBM1L1400, they call a pulse switch, maybe quad coded ? you would need to get one to see what it actually does.
sub $10, so a good price.
20 positions also finds an unusual Grayhill 60A18-4-RAC - looks to be a 20 detent rotary optical encoder with joystick switches.
higher price, at $48, at digikey, but looks to be designed for human interface uses. Quite nice.
For $80, I see Mouser have a Grayhill 20 step, absolute gray encoder (wrong image) single bank.
Mouser also show bourns absolute encoders, sub $10, but 16 steps gray. How important is 18 steps
There is a TT part code EN18ABHH22H0H0 for 24 step absolute, but no stock showing. (MOQ 720?)
Generic rotary encoders seem common in 18 or 20 PPR, some have push switch to select. A small display could tell you where it was set.
