Author Topic: squares for tonner transfer to copperclad board  (Read 626 times)
Offline m3vuvTopic starter
« on: April 10, 2020, 12:24:41 pm »
Hi alll,i build a lot of things manhattan style,ie glueing bits of copperclad to another board,just thinking is there a downloadable pattern for tonner transfer to create copper islands onto a pcb,sort of like a bunch of say 5mm squares with a 2mm gap?
Re: squares for tonner transfer to copperclad board
« Reply #1 on: April 10, 2020, 01:27:06 pm »
i know that i wanted something to print and iron on,thats the whole point of this post,cheers anyway.
Offline coppercone2
« Reply #2 on: April 11, 2020, 04:42:06 pm »
for something that simple you might be able to use a sharpie and ruler
Offline Wimberleytech
« Reply #3 on: April 11, 2020, 05:48:36 pm »
Go here and download this free software: https://www.expresspcb.com/
Download the "classic" version.
It is super super easy to use...learning curve maybe 10 minutes...prolly less.
I have been using it for years to make toner transfer PCBs.
The tool is designed to allow you to upload to their PCB mfg service, but it also lets you print to your laserjet, dimensionally accurate.
This example shows double sided, but I do not make double-sided pcbs, so these are done with wires.
