Author Topic: TSOP Series response time  (Read 1631 times)
Offline ElectricGuyTopic starter
  • Country: pt
« on: March 06, 2015, 10:01:46 pm »
Hi all;
Does somebody know the response time of a TSOP series device, like TSOP1738?
I want to know the time that takes when the modulated IR hits the sensor, and tha change in the output.
I didn't see that specification on the datasheet.
Thank you!
Thank you!
Regards
ElectricGuy
Offline suicidaleggroll
Re: TSOP Series response time
« Reply #1 on: March 06, 2015, 10:09:14 pm »
I'm not sure if I'm reading this right, but it looks like td (time delay) is between 7/f0 and 15/f0.  For f0=38kHz, that's 184-395uS (Figure 7):
http://www.micropik.com/PDF/tsop17xx.pdf
  • Country: pt
« Reply #2 on: March 06, 2015, 10:20:11 pm »
You're probably right! I send a message to Vishay. Lets see if they answer to this question.
Thank you!
Thank you!
Regards
ElectricGuy
