I'm trying to improve an old design that incorporates this battery charging circuit. Basic switching regulator, takes a PWM signal from a microcontroller, duty cycle is changed to achieve desired charging current.
I need to replace the MOSFET with one with a higher gate-source voltage threshold, since VCC will be increasing to 25V.
Why was a P-channel MOSFET used? These seem more expensive for the same performance.
What would need to change in the circuit for a N-channel MOSFET to be used instead? The PWM waveform can be inverted if required.
Any other thoughts on the circuit are welcome as well.
Cheers
