logic chip approach would be timers in series to break out your count into BCD, or a decade counter may suit you better
have a reference crystal (e.g. 32khz clock) to act as a gate signal, at 1 second you latch in the count on the timers, then reset the timer a cycle or so later, you then use some gates to break out the timer count into the groupings,
If passives are prefered, you could use some multi-pole band-pass filters to break up the groupings, then use either some transistors, or a shmitt trigger chip or an op amp to drive an output when the signal level is strong enough, in this example, it would work better with some overlap in the middle, so you always get a reading,
