Hi all,
I'm looking for a good solution to a problem. I've a moving mechanical part, without cables or anything, that performs a linear motion. I'd like to know position of this mechanical part, without adding anything mechanical to actual system (i.e. rotative encoder or encoder on moving part). What I can do is to add something nearby it.
I've excluded things like ToF or vision systems and perform some research. I've found some systems that use, on linear motion, magnetic encoders with sensor on stator and a ferromagnetic material on mover. What I'm aware is that system doesn't use single sensors due very high accuracy.
Do someone have idea on what kind of system they use?
I'd like a start point where looking for on my researches.
