Author Topic: Confusion about nixie tube 74141 outputs  (Read 1464 times)
Offline rea5245Topic starter
« on: January 08, 2018, 08:12:36 pm »
I'm building a nixie clock. I've built the circuit except for the nixie tubes themselves, and I want to test it before soldering in the relatively expensive tubes.
So I feed a BCD 1 into the 74141 chip and look at the outputs on a 'scope. Some of them show a steady 1.5V while others show 60Hz noise (so they're high impedance maybe?)
What puzzles me is that the pin for driving the 1 digit is not unique. I.e. it's showing 1.5V but so are a couple of other outputs. I could understand if all the other outputs were high impedance and just the 1 digit were at 1.5V (because maybe it's tied to ground but there's some leakage current going through). But why are a couple of the other outputs showing 1.5V?
Is this just a case of "everything will sort itself out once the circuit is completed with the nixie tubes and the pins aren't floating"? Or is there a real problem here?
Thanks,
   Bob
Offline fourtytwo42
  • Interested in all things green/ECO NOT political
Re: Confusion about nixie tube 74141 outputs
« Reply #1 on: January 08, 2018, 08:17:19 pm »
The 74141 outputs are open collector meaning they need a pullup current source to make any sense, you could temporarily connect a resistor, say 10K from each output to vcc so your scope correctly displays the output state.
Offline james_s
« Reply #2 on: January 08, 2018, 08:17:32 pm »
The 74141 has open collector outputs, so there will be no voltage on those pins without something external to pull them up.
« Reply #3 on: January 08, 2018, 08:34:22 pm »
But if the outputs are open collector, why would I be seeing 1.5V on some of them?
Offline james_s
« Reply #4 on: January 08, 2018, 08:36:19 pm »
Likely the protection diodes, leakage current, I assume you're measuring with a high impedance multimeter? You'll often get erroneous readings.
Connect a nixie tube or use a pullup resistor and it will work. You cannot accurately test an open collector part with nothing connected.
« Reply #5 on: January 08, 2018, 08:43:00 pm »
OK. Thank you.
- Bob
Offline David Hess
  • DavidH
« Reply #6 on: January 09, 2018, 01:17:02 am »
Counterintuitively, a 1.5 volt output in this case is the off state.  Inspection of the 74141 output stage reveals that when off, half of the outputs will produce a TTL high minus one Vbe as an output voltage which is indeed about 1.5 volts.  The Vbe is from the forward biased base-collector junction of the cascode output transistor which will become reverse biased and high impedance once the voltage is raised by the load of 60 volts maximum.
