I am telling you I have a tube here attached to a power supply on the test leads. when I turn it up it strikes at 77V. When I shine a UV light on it it strikes at 73V. Repeatedly.
Yesterday it was a bit different in the thresholds
I can also keep it unlit at 74V unlit, and when I turn the light on it turns on.
It seems dependent on the polarity too, if I flip the bulb I get different voltages.
And now I got my 15W led PCB exposer (UV led 15V diode @ 800mA). I can turn it on at 66V when it normally trips at 74V.
You can make a UV triggered gate with this thing.
update did a experiment:
turned on UV bulb 5 times. Each time it lit 74-75V.
I turned it off and set PSU to 55V. I incremented one Volt and flashed it with the 385 nm 800mA LED. I got it to turn on at 60V. This is 14V less then the normal threshold. But its dim. And if you drip the voltage even a little to 59V, it turns off. But it does stay on. This is with a 250V sorensen PSU (250mA). The light source is a 750mA 15V LED on a CPU heat sink that is regulated by a current source configured LT3080 that is ran off 20AA batteries, and its inside a metal box. the 60V trip threshold is repeatable. I hold the light so the neon bulb is almost touching the diode. There is no optics, just a hole in the aluminum panel.
this is 15V lower. Once it turns on this low voltage, its so sensitive to variations that it will turn off if you bearly touch the knob, I mean like 1 degree rotation.
If you ignite the lamp properly at 74-75V, and then lower the voltage, it goes out at 60V. This is precisely the minimum point that you can turn it on with the bright UV light.
My observation is this: if you determine the glow range for this neon bulb, (trigger 75, shines down to 60), it is possible to trigger it at 60V with a bright flash of UV light. So you can turn it on the absolute minimum voltage range.
I got a second bulb from the same lot. It turns on around 75V DC and stays lit down to 60V. The same thing occurs, if I adjust it to approx 60V, and flash it with the light, it turns on. These are whatever bulbs that are meant to replace the bulb in harrison power supplies.
I think the results are pretty cool. 15V is quite a bit.
I am sorry to say I am convinced and that book must be wrong or defining something differently. But its a visible glow to the naked eye in a lit room. And its striking at the minimum of its operating voltage.
I tried it with another neon bulb, this time a blue one. IDK what it is, I think its phosphor, but its a neon bulb that glows blue. Strike voltage is 85V with power supply. I can get it to trip at 75V with the UV light pulse. This one looks frosted, so I guess its attenuating the light, you can't kick start it as low as the clear glass neon bulb.
Since it works on two different NE2 bulbs and the blue phosphor neon bulb, I am gonna say this definitely works, and it works better on bulbs without phosphor.
