Author Topic: Is china power resistors are good or bad?  (Read 2026 times)
Offline coppice
Re: Is china power resistors are good or bad?
« Reply #1 on: September 26, 2019, 07:13:57 pm »
China is not a manufacturer. Some of the manufacturers in China are good and some are bad, just like any other country. You need to look in detail at the specific source of the part.
Offline 001Topic starter
  • Country: aq
« Reply #2 on: September 26, 2019, 07:23:42 pm »
Yea
But ebay sellers didn provide me with it
What is TYPICAL for this resistor type? Can I use it as brake resistors? What about inductance?
Offline coppice
« Reply #3 on: September 26, 2019, 07:26:32 pm »
They are usually a coil of resistance wire, potted in ceramic, so they have significant inductance.
The following users thanked this post: 001
Offline jhpadjustable
  • Salt 'n' pepper beard
Why china resistor users so agressive ?
« Reply #4 on: September 26, 2019, 07:30:15 pm »
"There are more things in heaven and earth, Arduino, than are dreamt of in your philosophy."
The following users thanked this post: Bassman59, Ysjoelfir
  • Country: aq
« Reply #5 on: September 26, 2019, 08:08:07 pm »
Offline Bassman59
  • Yes, I do this for a living
« Reply #6 on: September 26, 2019, 08:15:22 pm »
Yea
Well, your first mistake is buying parts from eBay.
  • Country: aq
« Reply #7 on: September 26, 2019, 08:47:56 pm »
I dont know local parts sellers here
Offline magic
« Reply #8 on: September 27, 2019, 06:28:44 am »
Ask the penguins :D
And there is a whole world of professional suppliers who offer international shipping.
edit
Even LCSC, if you want stuff from China. The difference is, you know who made the part and if you like it or don't, you can decide to order more of the same or something else in the future. Buying on eBay is pure roulette.
« Last Edit: September 27, 2019, 06:38:32 am by magic »
Offline Ysjoelfir
« Reply #9 on: September 27, 2019, 07:14:51 am »
Thanx a lot
And what about this type? https://www.ebay.com/itm/300W-500W-1000W-Aluminum-Housing-Wirewound-Braking-Load-Resistor-for-VFD/303101393993?hash=item4692403c49:m:mz1sTWOdJMjy2s5GgqgJoMQ
Do you even read the things you link to? ;)
300W 500W 1000W Aluminum Housing Wirewound Braking Load Resistor for VFD
Greetings, Kai \ Ysjoelfir
  • Country: aq
« Reply #10 on: September 27, 2019, 01:11:10 pm »
Thanx a lot
WHAT? Bifilar wirewound can provide about zero inductance
Offline Ysjoelfir
« Reply #11 on: September 27, 2019, 06:03:40 pm »
And you think that you get a >=300W Resistor with bifilar windings for under 20$? Sorry to disappoint you.
Offline GigaJoe
« Reply #12 on: September 27, 2019, 06:29:38 pm »
Offtopic: but ...   one day i pass by garage sale , an old man selling some old de-soldering parts,  he was so convinced that old 90-x can of foil caps cost 100x more then $5 ...  shaking some dusty old parts catalog  :)
cost of making parts are nothing now ....  (it up when spec's need to follow) i have such green resistor in 20W 10ohm only type,  it blow up when i push over 120W from audio amplifier to the single resistor :) even 60W it holds with heatsink ...
Offline MosherIV
« Reply #13 on: September 27, 2019, 08:12:05 pm »
Have you ever seen how those wire wound power resistor blow?
Well here you go
That by the way is NOT a cheap chinese part, it is a quality ARCOL part commonly used in automotive industry.
My colleague was also surprised to see it blow that way, he told me they normally  just shoot the wire and terminal out of the sides at high velocity !
Offline grifftech
    • youtube channel
« Reply #14 on: September 27, 2019, 08:26:34 pm »
Electric stove element.
