Author Topic: Online/double-conversion ups delay time?  (Read 1469 times)
Offline Daniel_ReyesTopic starter
« on: September 16, 2015, 02:15:33 pm »
Is an Online/double-conversion UPS truly instant? Any microsecond or nanosecond delay?
Sent from my SM-G900P using Tapatalk
Offline Chris C
Re: Online/double-conversion ups delay time?
« Reply #1 on: September 16, 2015, 02:19:04 pm »
Double conversion is always running from the battery, simultaneously charging it when AC is available.  Unless they've taken some improper shortcut, there should be no delay whatsoever.
Online wraper
  • Country: lv
« Reply #2 on: September 16, 2015, 02:20:42 pm »
What do you mean by instant? Since it is double conversion, the load is never powered from the mains but from internal voltage, and even can be of different frequency if particular model allows to set this. Load is never switched between internal/external voltage sources.
« Reply #3 on: September 16, 2015, 02:39:51 pm »
Do you think there could be a delay on the output sense so that the UPS does not latch and store a line fault in its memory? Just hypothesizing here.
Offline Magicmushroom666
« Reply #4 on: September 16, 2015, 03:47:08 pm »
A line fault (ie on the supply) would have nothing to do with the UPS output, as others have mentioned, the input is converted to DC internally before going back to AC. The output is always on and doesn't switch between anything.
The UPS i've worked with dont always report faults if they are very quick, but again this has no affect on the output.
« Reply #5 on: September 16, 2015, 03:54:16 pm »
Understood.  Thanks for the help everyone.
