Author Topic: Allowable On/Off times vs. current for a multiplexed LED Display.  (Read 1132 times)
Offline Electr0nicusTopic starter
  • Country: at
Hi
I have a 7- Segment LED Display (green). In the datasheet is noted:
max. Peak Forward Current 160mA
with a footnote that says: Dutycycle 1/10 max. on- time 0.1ms.
I have no problem understanding that spec for 1/10 Duty-Cycle, but what is if I only use a 1/4 Duty-Cycle and only 80mA max. current. Can I then increase the max. on time proportionally, so in this case half the max. peak current and double on-time (0.2ms)?
Kind regards
Gregor
