Author Topic: Uni-T UT210E/211B as current probe?  (Read 2671 times)
Offline iXodTopic starter
« on: June 08, 2021, 04:54:49 am »
Many of us have a scope current probe and don’t know it: the Uni-T UT210E (and it’s better DC-current-resolution cousin the UT211B).
I wonder why someone here hasn’t already lead the way to hack this and add a BNC output.
Anyone care to share their hack details?
« Last Edit: June 08, 2021, 02:00:08 pm by iXod »
Offline mikerj
Re: Uni-T UT211B as current probe?
« Reply #1 on: June 08, 2021, 09:00:13 am »
This may be useful for you:
https://thearduinoshed.wordpress.com/2020/04/13/uni-t-ut210e-current-clamp-hacking/
The extra resolution of the UT211B is of little relevance if you want to use it as a current probe, it may even be worse if the additional resolution required the hall sensor signal conditioning to have a lower bandwidth.  FWIW the UT210 only has a bandwidth of around 5kHz, but it can be increased:
« Reply #2 on: June 08, 2021, 12:31:35 pm »
It’s not. Joe stops short of the details, showing just the broad strokes. Tantalizing, yes.
Offline Gyro
« Reply #3 on: June 08, 2021, 12:38:18 pm »
This post may help regarding improvement of the UT210E by optimising the gain/bandwidth of the existing opamps. I don't know if the same circuit configuration applies to the UT211B...
https://www.eevblog.com/forum/testgear/a-look-at-the-uni-t-ut210e/msg3504060/#msg3504060
Best Regards, Chris
Offline Trader
« Reply #4 on: June 30, 2021, 06:52:54 pm »
Yes, in the video Joe didn't explain how to do that improvement.
