Author Topic: Alternative for IRFP240/250/260 in TO-220 package  (Read 1670 times)
Offline prasimixTopic starter
  • Country: hr
    • EEZ
« on: March 13, 2020, 11:32:39 am »
I'm looking for n-ch MOSFET with SOA similar to IRFP240/250/260 (TO-247) but in TO-220 package. I don't need it as a switch but to work in linear region as pass/series voltage regulator that has to step down no more then 5 V. What you would recommend?
Online Kleinstein
Re: Alternative for IRFP240/250/260 in TO-220 package
« Reply #1 on: March 13, 2020, 11:52:36 am »
One could use some higher voltage MOSFETs, especially old type. The IRF840 is at least in the Fairchild version specified with power limited SOA.
The permissable power may still be a little lower than for the TO247 case - just a question of the case size.
  • Country: hr
    • EEZ
« Reply #2 on: March 13, 2020, 11:56:10 am »
Thanks Kleinstein, the total power dissipation should not exceed 15 W, and thermal control will be implemented coupled with forced cooling using fan.
Online Kleinstein
« Reply #3 on: March 13, 2020, 12:27:20 pm »
For so little power, one could get away with a smaller MOSFET like IRR820.
If in doubt Infineon FETs are a good choice - the transistors may not be better, but the data-sheets usually have a reasonable SOA curve and not a fake one ignoring the thermal instability.
Offline Vovk_Z
  • Country: ua
« Reply #4 on: March 13, 2020, 09:04:33 pm »
There is definitely no need in TO247 case for 15W dissipation. A lot of TO220 case mosfets will do.
For example, popular low voltage devices are IRF3205, IRF3206 etc.
  • Country: hr
    • EEZ
« Reply #5 on: March 14, 2020, 10:10:50 am »
Thanks, I'll give a try to some of OnSemi devices, such as FQPF19N10 or FQPF33N10L that have DC specified in SOA and that are even suggested for audio amplifier applications.
