Author Topic: How to design analog filter using FILTER WIZARD website  (Read 2372 times)
Offline manjunathTopic starter
« on: September 21, 2014, 09:11:42 am »
Hi all,
      I am trying to design Analog low pass and high pass filters using the site.
 http://www.analog.com/designtools/en/filterwizard/#/typehttp://www.analog.com/designtools/en/filterwizard/#/type
I did not get how to select DB value in Stopband and Filter response selection.
Can anyone help me how to use this site.
Thanks.
Offline diyaudio
Re: How to design analog filter using FILTER WIZARD website
« Reply #1 on: September 21, 2014, 09:31:20 am »
Thanks.
There seems to be a bug when you change the value on the stopband value, anyways refresh the browser and you can changed the value. note as you increase the magnitude of the stop band so does the filter order the default is 2 stages (4-th order) at 40-db.
