Author Topic: Alternatives to terminal blocks for frequent wiring connect/disconnect  (Read 4743 times)
Offline djsbTopic starter
Are there any alternatives to using terminal blocks (with screws) for FREQUENTLY connecting/disconnecting wires to a PCB. All the screw less connectors I've seen are only suitable for pushing a wire in ONCE. They can't be used for repeated re-wiring. WAGO terminals are very good, but they can't be PCB mounted, and they aren't available as individual poles. It would be nice if there was something available that could be used without a screwdriver as well. Does anyone know of anything suitable? Thanks.
Hertfordshire, UK
University Electronics Technician, London, PIC16/18, CCS PCM C, Arduino UNO, NANO,ESP32, KiCad V8+, Altium Designer 21.4.1, Alibre Design Expert 28 & FreeCAD beginner. LPKF S103,S62 PCB router Operator, Electronics instructor. Credited KiCad French to English translator
Offline kripton2035
Re: Alternatives to terminal blocks for frequent wiring connect/disconnect
« Reply #2 on: November 23, 2019, 08:06:10 pm »
Take look at these connectors from Phoenix Contact https://www.phoenixcontact.com/online/portal/gb/?uri=pxc-oc-itemdetail:pid=1792216&library=gben&pcck=P-11-01-05&tab=1&selectedCategory=ALL.
They have a locking level, push the wire in, flip the lever, done. PCB mounting natch.
If that isn't exactly what you want, have a look around Phoenix Contact's catalogue, they have 1000s of PDB mounting terminal types.
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #3 on: November 24, 2019, 06:21:01 am »
I'm partial to pluggable terminal blocks, and the above spring-clamp kind are nice as well, especially convenient for industrial use.
Also partial to making my own plugs, but I have the hardware for that (housings, terminals, crimp tool), YMMV.
Seven Transistor Labs, LLC
Offline paul8f
  • Country: ie
« Reply #4 on: November 24, 2019, 08:22:40 am »
Just be aware that some cheap spring loaded clamp type connectors can lead to weak electrical connections, (especially over time if there is any type of vibration on the board.) A weak connection could mean a hot spot or a voltage drop in a high current circuit. The wires, even if tinned would also be prone to fraying and breaking off at the ends (think stereo speaker connections...)
Would it be possible for you to run wiring from the terminal blocks out to a pluggable connector? Cumbersome, but it might be the better option in the end as it would be quick and easy to connect/disconnect, and you're guaranteed good connection every time.
The following users thanked this post: Electro Detective
Offline Electro Detective
« Reply #5 on: November 24, 2019, 09:48:38 am »
as above  :-+ beat me to it  :clap:
Sometimes if you need 'walk away' dependability, it's screwdriver time..  :phew:
Offline ConKbot
« Reply #6 on: November 25, 2019, 04:59:44 pm »
Spring terminals with appropriate clamping force(i.e. Proper phoenix or similar connectors, not some un-named special) will be more reliable than screw terminals. High vibration environment? Always has tension, can't back off. End user tinned the stranded wire and put it in the terminal? Sping will move as the solder cold flows and doesn't lose tension like a screw terminal could. Takes a lot more creativity to over or under tighten it, etc.
Both should be pretty reliable if done correctly, with good quality components.  Spring clamp ones will be more variable with quality, screw will be more variable with use technique. If you control both, then its about a wash.
« Reply #7 on: November 25, 2019, 05:20:47 pm »
The OP, although he/she seems to have gone walkabout, said:
Are there any alternatives to using terminal blocks (with screws) for FREQUENTLY connecting/disconnecting wires to a PCB. (Their emphasis)
So this isn't for a 'walk away' application.
Interesting the UK mains wiring codes require (or they did when I was intimately current with them) that screwed connections are 'inspectable', that is, aren't placed somewhere where you can walk away and forget them. They're expected to be inspected, and adjusted if necessary, at regular intervals. Generally for 'walk away' applications that could not be regularly inspected crimp connections (properly made, adequately stain relieved, etc. etc.) were preferred.
Offline tunk
  • Country: no
« Reply #8 on: November 25, 2019, 05:44:19 pm »
Do a web search for this: KF141 terminal
Offline jbb
« Reply #9 on: November 25, 2019, 07:37:45 pm »
... FREQUENTLY connecting/disconnecting wires to a PCB. ...
You'll need to make some estimates here.  Many pluggable contact systems are intended for maintenance & servicing, so have a life span of 20 - 50 cycles (you'll likely get more than that in practice).  Check for 'lifespan' or 'service life' or similar on the data sheet.
The Molex Micro-Fit connectors are quite nice, but you'll either need to fork out for a crimper (look for a technician crimper) or buy pre-crimped leads.
I've had good results with Phoenix Contact in the past, for example using a part like this 32 contact DFMC 1,5/16-ST-3,5-LR (see catalog here).  (I can't remember the exact part, it was a few years ago.) It's only rated for 25 cycles or so.
If you need many cycles, you'll need to look for a plug & socket instead of a pluggable connector...
