Hi guys,
I'm working on a project where I would like to protect the input of some precision opamps from large differential voltages. To do so, I would like to use two antiparallel diodes on the inputs to limit the differential voltage possible.
The opamps in question are being used in a transimpedance configuration for a current-output DAC. As a result, leakage current must be very low. Because of this I was looking at using the BAS416 diode, which has reverse leakage in the order of pA. However, they seem to be all sold out on the distributors. Farnell, RS, Digikey, Mouser, all have none in stock.
Are there any alternatives that features similar extremely low leakage currents? Preferably in the same footprint since the PCBs are already out for manufacturing (stupid on my part, I know). In my case it does not have to be that extremely low, as my LSB corresponds to a few nA, but I would like to be sure that even in the worst case the diode will not be a limiting factor on my accuracy.
What are some similar parts to the BAS416 with regards to reverse leakage?
