The best thing you can do is go onto Farnell or Mouser, go to their connectors page
Select all connectors with the same pin pitch & number of contacts
then select the specific manufactuer (if it is printed on the connector)
then look through the list for ones the look similar and compare. It's what I usually do and I've got a pretty good track record doing it.
