Author Topic: ALTIUM 20 BUS with DIFFERENTIAL LINE  (Read 778 times)
Offline diego.tagnaniTopic starter
« on: September 04, 2020, 09:45:14 am »
Hi everyone. I have a big problem with an ALTIUM project.
I have a hierarchical block with differential ports. It is repeated 12 times.
These differential lines must go on connector.
The bus joins all the lines of the block with the name SiPM_K or A [1..12]. For the differential lines on the connector use _P or _N.
The compiler gives me an error, looks for the twisted pair on the name of the bus net and fails to match the two lines of the twisted pair.
I attach the schematics section and error line
Can anyone tell me how I can solve the problem?
Thanks for help.
Offline voltsandjolts
Re: ALTIUM 20 BUS with DIFFERENTIAL LINE
« Reply #1 on: September 04, 2020, 10:37:44 am »
Please do not double post.
You put the same query here:
https://www.eevblog.com/forum/projects/altium-differential-signals-harnesses-and-net-labeling/msg3217748/#msg3217748
Also, you should use the Altium board on this forum, here:
https://www.eevblog.com/forum/altium/
New topic here:
https://www.eevblog.com/forum/altium/altium-20-bus-with-differential-line-252736/
Mods: please delete/lock this topic.
« Last Edit: September 04, 2020, 12:23:47 pm by voltsandjolts »
