I have recently gotten the chance to try out Altium Designer (winter project over the Christmas holiday
But I immediately ran into a small problem that probably is very easy to solve for someone more experienced:
Using "Miscellaneous Devices.IntLib" and placing a resistor (res1) in my schematic using the place part command, there is only one footprint that I can select from "AXIAL-0.3".
I have to manually go into the footprint manager and add the RESC2012N (metric 0805 footprint) to this resistor from the "Chip_Resistor_N.PcbLib" footprint library. Or any other footprint for that matter (this is the same for capacitors and all other components).
Checking tutorials on Youtube, this 0805 footprint should be available already while placing the part in the first place, so this leads me to think that my libraries are not linked/installed properly?
