Sup EEVgang, first post here! I made this account hoping somebody more experienced than myself would be able to resolve a specific library management issue I'm having in Altium:
I understand that many PCB designers have a parameter for every part in their library which describes the status of that part, which is set to something like: blank when the part is created, "checked" when the symbol+footprint is verified, and "approved" when a board with that part works. That way, when I'm checking out a design, I know which parts are already good.
That's all nice and straightforward, but here's my problem: when I'm done testing the board, and I want to update the status parameters of all the parts I used, I have to manually go through each of my libraries and update the parameters one by one!
(or, alternatively, if I'm using a library local to the project, when I'm done with the board, I have to manually copy each part into the appropriate library)
Is there any neat solution to update a library from a part in a project? I've googled around, but all I ever find is the inverse -- how to update parts from their libraries.
Thanks in advance for the help
[insert back to the future reference here]
