Hey all!
I'm currently messing with a few particle detectors, mainly to explore femtoampere/ultra high impedance prototyping stuff, and wanted to assess commercial 'space blankets' as window material. hopefully it would be thin enough to let through most low-energy particles, but conductive enough to mitigate electrical noise in the detector. Also ideally it is gas-impermeable enough to be able to pressurize the chamber slightly.
So which side is conducting, again?
Neither! if a simple multimeter is to be trusted. But it might still be conductive enough to have some shielding capability.
The question is now: which side is aluminized. I cut two pieces of the material, put them on a level surface with either side up and put a few drops of dilute sodium hydroxide on each. Sodium hydroxide (NaOH) dissolves aluminium fairly rapidly, so ideally, one would lose its metal sheen fairly quickly.
The results were.. confusing.
The silver side out sees no attack after 15 min.
The amber side out turns completely transparent in the same time interval. But the amber color remains!
If you look carefully at the amber area, a small flake of translucent plastic can be seen.
What I think happens is that the base mylar material that aluminum is vapor deposited on is the "silver" side.
An amber layer of some film is then laid on top of the aluminum, for whatever reason.
So my conclusion is that the structure is something like
[[[[[[[[[[[[[[[[[[[[[[[[ <-MYLAR (COLORLESS)
//////////////////////// <-ALUMINIUM
]]]]]]]]]]]]]]]]]]]]]]]] <-POLYMER FILM (AMBER)
This makes the blanket useless as a conducting film, but might still provide some shielding, as the combined film can still couple capacitively to a earthed can.
I'm unsure to what degree this will work, though.
Hope this helps someone some time some where!
--Chris
