It is simply a VDR, a voltage dependant resistor. De dependence can be positive or negative, usually indicated bij a "+" or "-" sign near the diagonal line. In general a depndant resistor is represented by a diagonal line through the resitor symbol. What the dependence is can differ, can be voltage: V, temperature: T, light: L etc.
The example given has a wrong symbol. De numbers given actually specifies a zener diode or a "Transzorb" of 5V. Although its behaviour is voltage dependant it is not the same thing as a VDR.
