Although my main interest is collecting and repairing test equipment I do on occasions dabble in radio repair. I would like to do some before and after testing and see how a particular radio compares to the manufacturer’s specifications. If you cannot measure it how do you know you have made an improvement etc.
I’m today playing with a fairly typical domestic receiver of the 60s and 70s and need some practical advice on how to test the AM rejection against manufacturer’s specifications sheet.
The radio specifications quotes” 40db {Signal to noise ratio greater than 50db}
My IF is 470khz.
Having tuned in the radio to the signal generator do I then increase the frequency off generator by 2 x IF and make measurement with the modulation on and off to get the signal to noise ratio.
Where do I make the measurement I am guessing it could be at the output of either the IF stage or speaker dummy load. I should keep the signal level very low to avoid activating the ALC ?
Is the 40db part of the specifications telling me the amplitude of the image Frequency should be 40db down on the level at the frequency the radio is tuned too.
I have never done this before so just need some help with the basic setup and getting the procedure correct. I do have basic test gear including RF test sets.
Thanks regards Chris
