Hey
I have an Agilent E3633A PSU which can deliver up to 20A and the stock fan is quite noisy and runs all the time. I want to replace it with a "Noctua NF-A8 PWM" but i dont know if the Noctua fan is up to the task since the stock fan is a bit more powerfull, so i wanted your opinion.
Specs:
Noctua
RPM: 2200
Airflow: 55.5 m³/hour
Static Pressure: 2.37mm H2O
Stock Fan
RPM: 2950
Airflow: 67.2 m³/hour
Static Pressure: 3.55mm H2O
So what do you think, will it burst into flames at 20A with the Noctua fan ?
