Hi, there. I´m thinking of designing a driver circuit for acusto optical modulators. Short AOM:
https://en.wikipedia.org/wiki/Acousto-optic_modulatorBasic building blocks I guess: fractional PLL based XO, LC Bandpass, Amplitude modulation + On/Off Keying, Power Stage.
I´m currently stuck at the amplitude Modulation:
Analog Multiplier AD835 should work fine, but I would like to have somewhat higher max Bandwidth.
All voltage controlled Amplifier IC I found are linear in dB, which is not what I need, I would need linear to control voltage.
Any hints?
