Author Topic: Biphasic Pulse Generator  (Read 1713 times)
Offline otaylorTopic starter
« on: September 26, 2019, 03:45:49 pm »
I would like to build a biphasic pulse generator with 2 outputs which is controlled by an Arduino Nano. It should be able to output +/- 10V with a maximum current of 10 mA. The shortest adjustable pulse length should be 1 ms.
I attached the schematic I figured out so far. I'm basically using a 2-channel DAC, whose signal is amplified + shifted by an OpAmp in a differential amplifier configuration. I'm using a DC-DC converter to generate +/- 12V.
Do you think my schematic is fine so far or are there other details you would improve?
Thanks a lot! :)
