I got an Audio mixer kit but there is no available schematic diagram so I need help in making my own audio mixer with the following parts:
2, 100 ohm resistor 1/4w
10, 1k ohm resistor 1/4w
2, 10K ohm resistor 1/4w
1, 1M ohm resistor 1/4w
4, IN4001 Diodes
1, Red 5mm LED
4, 0.1 uf (104) ceramic capacitors
2, 0.0002 uf (22) ceramic capacitors
2, 1000 uf 16v electrolytic capacitors
2, 100K ohm Potentiometer
6, 10K ohm Potentiometer
1, 250v 0.2a fuse
1, 250v spst switch
1, 220v to 9v 200a transformer (secondary is center tapped)
2, UA741cp op-Amp
(Mains Voltage is 220v 60Hz)(ps: there was no circuit board)
