Author Topic: Hex Inverter behavior.  (Read 1962 times)
Offline kvrestoTopic starter
« on: March 07, 2016, 01:05:45 pm »
Hi Everyone.
I'm assembling an output circuit for the first time as shown in the included pic, but I'm seeing some strange behavior. The pic shows R32 as a 33R resistor, but I actually have a 0R resistor installed at the moment. The other side of the FET is a led tied to 3.3V with a current limit resistor. The inverter is actually a TI SN74HC14DR.
When OUTPUT2 is at 3.3V the led on the other side is turned ON. When OUTPUT2 is at 0V the led blinks OFF briefly and then is slowly turns back on. When I connect my DSO probe to pin 6, then instantly the led turns off. When I remove my DSO probe again the led turns on slowly until it gets to full brightness.
Can anyone give me some direction as to what is going on. I'm thinking of swapping out the 0R for the 33R, as in the past this has improved other issues I've had, but I'm a bit confused in this case as to what is happening. Any help would be great.
cheers
kvresto
« Last Edit: March 07, 2016, 01:08:30 pm by kvresto »
Offline T3sl4co1l
    • Seven Transistor Labs
Re: Hex Inverter behavior.
« Reply #1 on: March 07, 2016, 01:25:13 pm »
There's an LED in the text but no LED in the schematic, and no power pins shown on the logic device.
Seven Transistor Labs, LLC
« Reply #2 on: March 07, 2016, 01:28:39 pm »
I certainly diiiiiiiiiiidddddd NOT!
missed the ground :)
How embarrassing. Its now 12:24 am, I'm tired, time for a break I think.
thanks
also thanks Tim. I know I haven't included everything in the drawing.
