Hello friends,
I simulated a car regulator circuit using samples available on the internet.
Instead of using BJT transistors, I used MOSFET in the circuit.
Based on the coefficient of the rotor current, I placed a voltage source dependent on the current.
The simulation results were not good, and the output ripple was high (which I also observed in the real output).
In addition to the transistor base circuit, I also used a Schmitt trigger circuit to generate a PWM wave in the MOSFET gate, but it had no effect on the output.
