Author Topic: JST-Style PCB connector for coax shield  (Read 527 times)
Offline mzy12Topic starter
  • Country: ie
« on: November 11, 2024, 04:43:31 pm »
Hey!
I'm designing a PCB that I want to have disconnect cable, ribbon cable, whatever, on it's edge so I can disconnect some analog cables with coax shield for when I want to/need to repair the board or anything around it.
I'm struggling to find the best way to terminate the shield surrounding the cable to a JST style multi-pin connector. Obviously, you can't just crimp it like the rest of the wires in the bundle, as the crimp relies on a standardised wire guage and insulation around the wire, neither of which a shield has. I could obviously use something like a multi pin din or 6.35mm jack and plug and terminate it like a standard audio cable, but that would be pretty bulky for what I am trying to achieve here.
If anyone has any thoughts or suggestions, I'd greatly appreciate it :)
Online reboots
    • http://reboots.g-cipher.net
Re: JST-Style PCB connector for coax shield
« Reply #1 on: November 11, 2024, 05:32:27 pm »
Is this for production, or a one-off?
I would solder a short length of insulated wire to the braid, suitable for crimping. I would add a piece of adhesive-lined heat shrink tubing over the braid and cable jacket to keep everything from moving around or shorting out.
The following users thanked this post: mzy12
  • Country: ie
« Reply #2 on: November 11, 2024, 10:12:46 pm »
Aaaah I knew there was obvious solution I was overlooking. Thanks for the suggestion hahah.
Just something on a small PCB for myself. Nothing crazy, but I still want it to be a reliable solution :P
Offline ZGoode
  • Grad student by day, equipment nerd also by day
« Reply #3 on: November 11, 2024, 10:26:58 pm »
It really depends how much vibration this device will be under.  If you're really worried you could add a little hot glue to the connector to make sure it does not accidentally come unplugged.  As long as you do a good job on the crimps themselves, you shouldn't be too worried about them coming undone.
Offline ajb
« Reply #4 on: November 11, 2024, 10:39:57 pm »
Crimping the shield (assuming a braided wire shield) isn't necessarily out of the question.  It's easier if you have a drain wire, but you can comb the shield wires out and then twist into something approximating a wire, sleeve it with heatshrink, and then crimp normally.  Doing that in production would require some care and qualification to make sure it can be done efficiently and reliably in volume, but for a one-off personal thing it's not a big deal.  The crimp between the wire strands and the terminal is the most important one and provides most of the pullout strength, the insulation crimp is mainly there for strain relief -- some terminals don't even crimp the insulation.  So as long as the effective cross section of the shield wires is within the range of the terminal, and any insulation isn't so thick that it prevents a proper crimp, it's probably fine.
  • Country: ie
« Reply #5 on: November 11, 2024, 11:42:38 pm »
I was under the assumption this was a big no no in the world of crimping :) I'll give it a shot anyways, it won't kill anyone :P
Offline kmm
« Reply #6 on: November 12, 2024, 02:02:53 am »
I've seen this done quite a lot in lower-end products for board-to-board audio interconnects. I recall most of the CD drive audio out to motherboard cables I saw back in the day just twisted up the braid and crimped to it, often with a JST style connector on the CD drive end
Online tooki
« Reply #7 on: November 14, 2024, 06:05:46 pm »
I have also seen this on a ton of audio/video gear.
Ideally, look for a connector with contacts that are available in a wide enough wire size range that you can get contacts suitable for both the conductor and shield. Depending on the connector, there might be different contacts for different wire sizes, or it might be a single contact style. In either case, you’ll just need to use a different crimp die opening for them.
Or you can use identical contacts and crimp die for everything, just divide the shield up to multiple contacts to reach the same gauge as the conductor.
« Last Edit: November 14, 2024, 06:08:49 pm by tooki »
