Author Topic: Interfacing 24VDC to 5VDC. How decent is my solution?  (Read 14583 times)
Offline Kjelt
Re: Interfacing 24VDC to 5VDC. How decent is my solution?
« Reply #25 on: April 26, 2015, 09:58:57 pm »
In almost all cases there will be a 3-phase VFD or inverter for DC motors in the same switching cabinet from what my device will be powered and controlled. Or big thyristor power controllers for high temperature furnaces. I expect, that in most cases the cable that provides power and input signals is not longer than 20-30 m.
I would consider that medium length cables in a noisy environment (depending on motor wattage) but I would recommend using an optocoupler and isolate the ground as suggested earlier.
Offline 128erTopic starter
« Reply #26 on: April 29, 2015, 12:30:22 am »
Here is what I have done until now. It's not finished yet. Some connections are missing, values wrong. And I defenitly want to minimize the number of code switches. At the moment there is one for each input, to decide which modules should be switched on.
Offline Kjelt
« Reply #27 on: April 29, 2015, 07:56:28 am »
Make sure you test and get the layout around that led driver correct. My experience three years ago with a Maxim led driver doing 700mA was that it needed an additional small filter because it jammed around the 100MHz (FM band).  ;) not sure about this driver though, but is wort while testing before ordering large quantities of pcbs.
Offline Jeroen3
  • Embedded Engineer
    • jeroen3.nl
« Reply #28 on: April 29, 2015, 08:55:45 am »
You can turn those rotary selects into potentiometers with some resistors so you only need 1 ADC line per rotary, instead of 4.
Or you can multiplex digitally, then you only need 7 inputs. Or multiplex analog, with 1 adc and 3 digitals.
There is no need to give them up for the pincount.
« Reply #29 on: April 29, 2015, 10:24:30 am »
That's a good advice. But in this case it's a linear LED driver. And I think the PWM signal to it, won't make any significant difficulties, too.
The pincount of the MCU is not a big deal. It's more about board space and minimizing the "user interface". And maybe minimize parts for cost. But I will think about the solution with the ADC as an input for the rotary switches. I have  done that with Keypads before.
