Author Topic: ADC Input Track Layout  (Read 1928 times)
Offline geo_leemanTopic starter
    • Professional Website/Blog
« on: May 29, 2016, 04:34:58 pm »
Hi all,
I'm working on a project that uses the MAX11040K 24-bit ADC https://www.maximintegrated.com/en/products/analog/data-converters/analog-to-digital-converters/MAX11040K.html]([url]https://www.maximintegrated.com/en/products/analog/data-converters/analog-to-digital-converters/MAX11040K.html)[/url]. I have some sensors that are driven with a 250 Hz square wave and I read their output voltage on the high and low segments to determine their value (that's a whole other story). The sensors output goes though a LMC6482 as a buffer, then to the ADC. My question is do I need to worry about impedance control on the ADC tracks? The buffer should drive the ADC just fine without much thought to this right? After much googling I didn't find much design advice for the input traces, just lots of information about routing the digital and analog separately/at right angles, etc.
* ADC Input Impedance ~ 130k
* LMC6482 Output Impedance ~ a few hundred ohms?
Thanks!
Offline Yansi
  • STM32, STM8, AVR, 8051
Re: ADC Input Track Layout
« Reply #1 on: May 29, 2016, 04:54:19 pm »
Worry about what? Track impedance at 250Hz soft-transitioned analog signal?  Really no.
You should be well more worried about your grounding system on the PCB, or using the differential inputs from the ADC correctly. Otherwise, with a bad layout and a few sources of EMI you can easily reduce the effective resolution you could get from the adc to below16 bits in some extremes due to induced noise.
« Last Edit: May 29, 2016, 04:59:45 pm by Yansi »
Offline nctnico
« Reply #2 on: May 29, 2016, 05:14:52 pm »
A 24bit ADC which has no ENOB specification should make alarm bells go off. Also using an external buffer will probably do more harm than good (offset and non-linearity). Did you look at TI's offerings? TI has 24bit ADCs with an internal buffer which can also be taken into account when the device self-calibrates.
When it comes to routing the signals: make sure there is no current flowing in the traces between the ADC what is being measured.
Offline JPortici
« Reply #3 on: May 29, 2016, 05:31:33 pm »
which is also a maxim part. or has thing improved recently?
« Reply #4 on: May 29, 2016, 05:49:39 pm »
Thanks for the input. I have Rev.A of the board and don't really have any signal integrity issues, so that's a good sign. The measurements have been rock solid.
This isn't an ideal part, but was the only thing I could find on the market that did what I need - many kHz sampling of 4 channels at 24-bits. As for the buffers - I have to provide a very high impedance input for the sensors. They are electrochemical and any dc bias/current will eventually harm them (hence the square wave driving and buffers).
