I'm repairing an LC-Power Arkangel3 850 W PSU which suffered a rather spectacular failure in the mains rectifier section. It uses two GBU1508 bridge rectifiers in parallel, mounted on opposite sides of the same heatsink.
There's strong indication that the failure was caused by a flashover between the + terminal of one of the bridges and the heatsink. Because of the asymmetric construction of the GBU package, the bridge that popped had its terminals significantly closer to the heatsink than the other. A large portion the terminal was completely vaporized, with clear evidence of arcing to the heatsink. I'm planning to modify the heatsink to provide adequate clearance.
This got me wondering about the reason for using two bridge rectifiers in parallel in the first place.
The obvious answer would seem to be current sharing, but bridge rectifiers don't necessarily share current particularly well: small differences in forward voltage, thermal conditions and even PCB resistance can cause one of them to carry more current than the other.
What puzzles me is that I see the same arrangement in considerably more expensive (and presumably better built) PSUs as well — for example, Corsair and Seasonic units I've worked on also use two bridge rectifiers in parallel.
So what is the actual engineering reason for using two bridges rather than one larger bridge?
Is it primarily:
a) increased current capability / thermal spreading,
b) higher surge-current capability,
c) lower conduction losses,
d) availability/cost,
e) something else?
And, assuming the thermal design is adequate, would replacing the two parallel 15 A bridges with a single high-quality bridge rated at roughly twice the current be a reasonable design choice?
I'm particularly interested in how this behaves in an active-PFC PSU, where the input current waveform is quite different from that of a simple bridge + bulk capacitor rectifier.
