I did read something however that said an inductors tcl corresponds to about 70 percent of its mu. I dont know if i measured an inductor with a extremely high mu or if my test setup was wrong or if i tested to too high a temperature, i.e. i tested to a 40c delta above room temp and the mu*0.7 rule only holds true close to room temp.
Material TC is all over the place. It's usually a lumpy response with respect to temperature, as different domains become activated. (Materials not optimized for flatness typically have mu ~proportional to temp, on the whole.)
Mu in most ferrites will be large (2000ish), but this doesn't matter much because average mu (what matters to the inductor in terms of turns and electrical properties) is reduced by an air gap. Air gap is usually dominant (i.e., mu_eff << mu_r), so that you'd only expect to see the tempco of the airgap dominate, which should be a modest positive tempco corresponding to material expansion rate. (Because, the air gap distance increases, reducing inductance, but the cross sectional area increases twice over, giving a net increase.)
Powdered iron depends on the mix used. I don't remember offhand how it usually varies.
Air core inductors are typically positive tempco, though you can use differential TCEs to make them behave differently. IIRC, some PCB mount "spring" inductors have near-zero TCE when mounted on FR-4 (which has a much higher expansion rate, stretching the inductor faster than it expands).
Resistors and the better capacitor types can have quite low TC, which is nice. Beware the GBW contribution, which itself has a TC -- and good luck getting a guarantee on that parameter from the manufacturer!
